I'm really confused about these voltage drop calculations and about finding a proper cable size to use for my situation.
I have 5 lights that need to be powered using a 120/240 volt single phase 3 wire source. The lamps are 120V, 300 watts each. The distance (one-way) from the source to the lamps is 3170 ft. Is the full load current just 1500W/120V = 12.5 Amps? Or is it different since I am coming out with a 120/240 V source?Can someone PLEASE send me the equations I need to calculate the line to line and line to neutral voltage drop and the %Voltage drop. Thank You.
