Voltage Drop Calculator
leverboi
Mike,
I am looking for a Voltage Drop Calculator online for use on 600 Volts for the Canadian Electrical Code.
Hope you can help.
Best Regards
Leverboi
leverboi said:
Mike,
Hope you can help.
Best Regards
Leverboi
Do a google search. I found this one for you. www.liteco.ca/voltagedropcalculator.aspx
Does the canadian code use metric sizes? If not any caculator would would do. There is on at Mikes home page under free stuff.
Try Alcan, contact Alex Mak/Senior Feild Engineer, 604-675-2011. I haven't validated it, but it might help.
Good Luck
The supply voltage does not effect the voltage drop calculation. Votage enters into the calculation only when deetermining the percentage of voltage that you are allowed/willing to lose. The calculator that Mike has on his site should be useable regardless of the supply voltage.
