When you use these voltage drop calculators , when it says half the lenght for a 120v circuit this means use the lenght of the pipe right? Meaning if you have a 300 ft run that is the # you put in, not 150ft.
Not sure try 150' and see if it correlates with the online calc. postedThe one I am using says half the lenght . Which means if the pipe is 3oo ft long that is the distance you use not 600 ft because of the return right?
