Nom Deplume
- USA
I am trying to calculate the VD on a string of light poles.
Do I calculate the VD at each pole by using the current at each pole and the distance to the source?
I have six poles that are 100' apart with a 275' home run.
The poles are 600 watts (3amps) each and will be at 240volts.
We will be using #6's for the wiring on 30 amp CB's.
By using this method, I am getting a 2.03% VD at the first pole and 0.95% VD at the last pole.
Is this the correct method to calculate the VD on a circuit that will be dropping load the further you get from the source?
