Which comes first, the derating of a wire or the voltage drop calculations? I have an EV charger that is 500' from the panel, it requires single phase 208 volt 32 amps and 120 volt 16 amps. when I do the voltage drop calculations, I get #4s are required for each circuit. If I'm installing in a single underground conduit, this would be 4 current carrying conductors which the code requires to adjust to 80%. How do I calculate for the adjustment factor?
