- Lockport, IL
- Retired Electrical Engineer
Anybody know how a VD calculation might change, when you are dealing with 400 Hz? I know that inductive reactance increases and capacitive reactance decreases, with an increase in frequency. But does that significantly alter the voltage drop along feeder or branch circuit wiring, or is it a second order effect?
We are adding a third hangar to a facility. The 400 Hz inverter has spare capacity, but we are concerned about the distance from the inverter to the new hangar. Can I use the same Excel spreadsheet that I use for 60 Hz VD calculations, and simply disregard the effect of the higher frequency? Or is there a separate equation that I need to bring to the party?
