ohmhead
- ORLANDO FLA
Well question i have a 1200 amp /480 volts /3 phase / length 600 feet /aluminum / pvc /emt raceway one way underground and over head raceway to a swbd i need a voltage drop calculation this is just a basic question no engineering programs or input needed.
I see paralleled feeders just for sake say 4 runs do you calculate each conductor meaning divide up the voltage drop or use the total resistance of the combined conductors by the number of them in the raceway .
Give me a example of the simplest formula i see page 49 in the Uglys book and they are multiply feet x amperes then divide permissible volts loss by 1000000 and divide this by 7200 .
What is 7200 ?
Why or how does this example work please explain if you can .
Could i just divide up voltage drop per conductor in the run and use just the current of one conductor for this .
This is just for my benefit to understand better .
What is 7200 ?
