I am having a difficulty time wrapping my head around a formula that I found on a voltage drop calculator. In the calculator, in both 3 phase and single phase, there is a "Current voltage drop to NEUTRAL" which uses the standard VD calculations (Vd=2KxLxI/Cm or Vd=1.73KxLxI/Cm). Now my issue is with the next calculation, which states "Current Voltage Drop PHASE to PHASE" and it take the VD from the standards formula and multiplies it by .866. The VD percentage uses that VD (.866xVd) figure divided by voltage. Now I don't know where they get the .866 figure and how it works. Can anyone help with this? Thanks.
