I have a square D motor data calculator (slide rule type).  It lists 3 phase voltage drop for each wire size for both 95% power factor, and 80% power factor.  The numbers are given in "Line-Line voltage Drop Per Ampere Per 100 Ft. in Magnetic Conduit and copper wire".
The odd thing is how voltage drop varies with Power factor and wire size. For large wires (2/0 or bigger), Voltage drop is smaller for 95% power factor. This is what I would expect.
For small wires (#1 and smaller), the voltage drop is actually greater for 95% PF than for 80% PF. Does anyone have any insight why a better PF causes a greater Voltage drop on small wires?
Steve
Steve
