mjf
I will start by saying that I have never had to figure anything out having to do with voltage drop. Occasionally I have upsized conductors.
Just curious, when figuring the length of a run when doing calculations, what do you use as starting and ending points?
Transformer and first OC device?
What if the run you're calculating begins 3 panels downstream from the main?
