enireh
- Canyon Lake,TX
when figuring voltage drop for a residential service, what is the minimum one should allow? 3%?
NYC amendments made voltage drop recommendation a code!There is no requirement to calculate voltage drop for a residence in the NEC and there is likely no need to worry about it. A standard load calc is all that's necessary.
Sent from my SM-G965U using Tapatalk
SECTION 210.19At what load do you calculate it for a residence?
