I am wondering about how to accurately assign amperage values for voltage drop calculations.
For example, lets say you have a continuous duty load at 16 amps. After you multiply by 1.25 you arrive at 20 amps. Which number do you use to determine voltage drop in the circuit?
Another example would be a receptacle with no specific load, could be anything plugged in. How would this be approached?
Another example: A PV inverter. These are rated to a certain output but rarely reach 100% possible amp output. Do you have to use max amp output in this situation?
thanks
thanks
