Mike, I am a residential electrician, I use a contractor license to work in Pa.
I worked overseas in crazy poor areas.
I studied 2 years in the USA to learn the codes.
On top of my degree from a French technical school overseas.
One of my customers has a large commercial building, he has 208/120 panels and 277 panels,
He asked me to add an outlet in a large closet space.
I tapped into a 120 outlet that was there
Parallel using MC 12/2 7-8 feet long max.
He plugged an Ethernet transfer switch 4.0 amp.
Half the lights in that place flickered and we had a voltage drop of 8 volt after loading the circuit with the switch.
Plug a 50 watt chip light and the drop is 18 volt.
Hot to ground stayed 122.
The lights are all on the 277 circuits not on the 120
It is a 20000 square foot open building used for pickle ball.
I did tell him to get a commercial electrician.
Any thoughts ?
Thank you
Any thoughts ?
Thank you
