SourceElectric
New User
- Texas
- Electeician
I was wondering about Voltage Drop. What I’ve always done but I wanted to see what others have done as well. On jobs where I’ve had to run a really big wire because I am going a pretty far distance. Let’s just say 400 or 500 feet. I can’t land that on a lot of the lugs in the panels on each side, so I normally just Polaris block down to a smaller size wire. I usually do this on both sides and I probably limit that piece of wire to maybe 5 to 8 feet long. I’ve never had a problem With Voltage Drop by doing this, but have others done this?
Also, the one I’m doing now is a three phase service but the same thing applies that because of the distance it’s requiring me to run three sets of parallel. I wanted to know if on each side, I could connect those three parallel runs to a single wire with the polaris blocks, granted that that one wire is big enough capacity to handle the load (amps) but would still allow it to function with no Voltage Drop or within the .03 percent allowed? Thanks for anyone’s help.
