sduckworth
I have a situation where i need to run quad app 600 feet to feed a 15
hp water pump from a generator(60kw), if possible. This is neccesary because of the unique situation involving the customers equipment and backwater... which i won't bore you with. Motor voltage is 460, full load current is 21A. I have done the voltage drop calc's serveral different ways to try and size conductors. I am somewhat confused on the proper way to approach this situation, mainly what is the proper method to calculate voltage drop and what about initial starting current.
