voltage drop
I have lighting circuit that has 13 -2x4 fixtures on it . The first fixture is 180 feet from the panel. Then there is 8 feet between each fixture. I'am sharing a nuetral for two circuits. The service is 3phase 208v. That would make it about 280 feet to the last fixture. I used the voltage drop calculator with the worst case scenario 10.5 amps at the end and it came to 8 wire. I believe that if i knew how to calculate at each fixture that 10 wire might make it. ??
You could figure it 'point to point' dropping the load of one fixture each time. Is there a job spec you are trying to meet?
That said, I would run 10 AWG as the home run, use 12 AWG from fixture to fixture and feel great about it.
If I had a spec to meet I might even break it up into two circuits just to avoid wiring 2 x 4 drop ins with 8 or 10 AWG, that would be a real pain.
No spec. But that is a good idea to break the two circuits into 3, pull 12's , share the nuetral and walk away
