voltage drop
what is the voltage drop for 100 amps going 550 from utility pole . I have over head triplex for the first 200 feet then I can run in conduant using copper may be 250 MCM
& for the triplex 4∅ thank you
chris kennedy
Miami Fla.
60 yr old tool twisting electrician
I know, that was why I said I assumed 240. :cool: but the amount of volts dropped would be the same, just not the percent.
That wasn't really directed at you Bob, I see all 3 assumptions. I was thinking OP may provide more info.
Also would like to add that OP didn't say if 100A was the OCPD or the actual load.
