hi folks , pretty new here
my dad and i are electricians .....me 23 years , my dad 40 years ,
i havent seen what im going to explain, its only work of mouth from my dad.
his friend has a fairly new ac compressor at his house on a 2-pole 40 amp breaker. He told me when utility company lowers voltage during extreme heat, 2-pole breaker trips. I assume that the drop in voltage causes an increase in amperage . One of my friends told me that he put a shunt trip on HIS own compressor ,as to not to damage the compressor or capacitor on the unit .
One idea i had that was shot down was to check wire size and see if a bigger breaker (5amps More) would stop breaker from tripping, but i was told that that would damage the capacitor being that it would allow a lower voltage into the unit and ruin it. My dad told me years ago he installed something MANY YEARS AGO, so that the reduced voltage would not affect the compressor.
He said it MIGHT BE CALLED A BUCK N BOOSTER OR A STABILIZER
Evidentally the homeowner wants the ac to still cool the house even with the brown-out. Is there a product that he can install that cant keep the compressor running at normal voltage . Its single phase 220 volt system , maybe i could increase the voltage to 240 , so that if they lower the voltage , id still be in the 220 volt ballpark
As i said , i havent physically seen it yet , but the breaker definitely trips when they lower the voltage.
i know its alot of typing , but wondering if anyone can help.....THANKS
