Voltage from a pump of a water well ?
These happen when I was working to find Magnetic field in a house.
The house is build on a side of a small mountain, where the is no water supply from municipality, I found a voltage of 6 volts between the house grounding rod of the main panel and the ground wire coming from the cable of the pump locate in the water well ( locate 30 feets of the house). If I connect them together i got around 1 amp and a magnetic field of 35mG all along the circuit and that happen when the main breaker is OFF.
I also find the same six volts beetwen each of the two line wire who are coming from the pump and the ground rod.
When the power is ON in the panel everything in the house is OK except the magnetic field around the pump cable who is always there.
On the opposite side off the water weel, there is a distributor transformer (around 50feets from the house) where the transformer ground rod look's OK
I have disconnect the ground wire coming from the pump water well and everything is work OK, (whitout magnetic field around the cable).. except for the ground protection at the pump.
Where is coming from these six volts ?
Do you think there is a electric ghost around this house ? if not , what that could be ?
Thank you for your interest
