brother
In my area it has been a practice to use gloves that were double the rating the voltage you would be working on.
Basically, if you have a 120/240 system, you would have gloves rated 500volt. If it was a 277/480 system, then you had 1000 volt rated gloves. At least this is what I have always done.
Kinda of like the rule of thumb when doing an insulation/megger test on wire, we have always doubled the voltage that the wire would be used on. 1000v meggering on 480v systems, 500v meggering on 240v systems.
Just recently a friend of mine said the company he works for started only sending them 500v rated gloves for their work, which is alot of 480v. Would there really be any issues with them using the 500 on 480v systems??
Maybe its just me, but I like a good measure of safety (more than 20 volts) when I got my hands on something hot. I also noticed that the 1000v tend to be more durable.
What is your opinion??
