am troubleshooting a jaccuzzi whirlpool tub that will show voltage from the water to the waterline i havechecked all bonding connections local power has checked their meter connections at this time i haved pulled a new home run to the tub with only this circut on and the tub unplugged i will read 3.5 to 4 volts on my meter {i drop one lead in the water and put one lead to the waterline under the tub } if i turn on other circuts on this voltage will drop or rise depending on which phase the circut is on if on same phase the voltage is higher opposite phase it is lower my meter is on 200volt not on amps any ideas
