SsmondsElectric
- Sergeant bluff, IA
- Electrician
Trying to figure out why there would be 1 volt of AC running thru a house water. House is on a hill has its own well, everything is in pex except for where it comes in to the basement, at the water heaters, and at the fixtures are copper pipe fittings. This is a very large house. It has an 800 amp service with a low voltage lighting system. I thought I would get rid of the voltage by adding two more ground rods at the service that did nothing, I grounded the copper pipe at the well entrance to the house and above the water heaters still did nothing. I went and ohmed out every branch circuit neutral in the five two hundred amp panels to ground, still found nothing. I am at a loss of where I should look next. Any suggestions we be greatly appreciated thank you
