Voltage issue
Qojoe
Long island
Hi everyone, to make a long story short as possible i was on a job where another electrician installed 2 homeruns for a/c condensors. This is a building with an apartment and 2 seperate meters. Both panels are in the basement next to eachother. When i turned off the breaker to one of the a/c comps i still read 3 volts on the actual breaker itself. When i went over to the other panel and shut off that a/c comp then the voltage on the 1st a/c comp went to 0. Both wires are stapled together along the joists. I have never seen this before and was hoping someone could explain. Thanks
Sent from my SAMSUNG-SM-N920A using Tapatalk
161123-1640 EST
Qojoe:
Connect a 100 W 120 V incandescent bulb in parallel with your meter. This is around 10 ohms with a very low voltage like 3 V applied to the bulb. If your meter reading goes to 0, then you probably have a capacitively coupled voltage from the close proximity of the two cables.. Otherwise we need more circuit details.
