I read an article about how uping the size of the conductors in a circuit over the period of one year resulted in quite a bit of savings as apposed to an identicle circuit sized correctly.
While discussing this issue a question arose. If the service drop on the utility side is undersized would this have an effect on the overall efficiency of the system beyond the meter since it was already dropping voltage and causeing the system as a whole to pull more amperage to maintain wattage? I say that it would not affect it in that we are talking about efficiency from the meter to the loads. not on the system ahead of the meter and all we were trying to do is to slow the meter as much as possible to the same loads waying cost of wire and termination methods. One wire size up theoretically losses 25% less wattage over a one year period assuming an 8 hour run everyday on a 20 amp circuit over a 50' load center length. Am I wrong or can anyone lead me to more info that would help convence this friend? either way would like to know.
Just an experiment with theory.
Thanks
Thanks
