 - Chapel Hill, NC
 - Retired Electrical Contractor
A member of our local Association called me and said he had 40 volts from roof to ground rod.  He said the gutter guys were there to install the gutters and quit because they were getting zapped.
So the member pulled the meter and disconnected the load side neutral from the meter base. Still power on the roof. I told him that maybe something was coming in on the water lines since it was city water.
He added that there was high tension wires near the home. I didn't think that could be an issue especially enough to zap someone but we have all seen fluorescent light bulbs light under the wires.
Anyway, the next day another member of our group volunteered to take a look especially since he is an electrical engineer. The voltage on the roof that day was 250 volts. I assumed stray voltage but you can't get zapped from stray voltage- I thought.
Anyway, they took a wire connected it to the roof and then to a ground rod and problem was solved.
That is all the info I know but I was curious if anyone has had that experience. Can you really get 240v from high tension wires? The power company stated that at certain times of the day the voltage would go higher and lower.
If this is true why would they allow a home to be built by those wires.
