Voltage on Breaker
Hfalz1
Houston, Tx.
Why am i getting 9.0V on a breaker that is off in a 3 phase panel? Single pole 20A. Only 4 receptacles on the circuit. Nothing plugged into them no load.
As others stated. Most likely “ghost voltage”. If your In the profession of trouble shooting a decent amount get your self a fluke 117 or something with low impedance mode (LowZ).
Got one several years ago and absolutely love it.
Adding a load at the test points will drop the voltage. Sometimes just another tester.
We used Fluke T+Pros so we all had the same information when testing. IDR the exact circumstances now but we didn't trust what one tester was showing us. Adding a second, then third dropped the voltage each time.
Only 3 circuits in one conduit. ABC phase with neutrals and one ground.
Like others have indicated - likely "ghost" voltage.
You say there are 3 phases in the same conduit. And the breaker you are measuring at is one of these phases? But the other 2 are hot?
If so, then you have 3 wires (2 of them hot) running all alongside each other for however long the conduit run is. This makes a really crummy, but still legit, capacitor - and the dead phase just shows up with a small capacitively coupled voltage because it's in the vicinity of the other 2 hots for a long enough length.
You can only measure this with a high impedance meter - because it introduces no load on that leg to drag it down. That ghost voltage will likely disappear the instant you load the circuit with just about anything (except LEDs ;)). Try plugging in a small incandescent bulb in see what happens to the 9 volts.
Would clamp meters (fluke 374, 375, 376) be high impedance or? Thanks.
This is why the electronic breakers trip ... "Phanton." voltage.
See my proposal for update to NEC.
