mtiede
- Grand Island NY
- retired
Ooops, I just noticed this forum was "For Electrical Professionals". I have a Physics degree. Does that help? ;-)
So I was trying to replace a fan switch in a bathroom to a countdown timer switch. I bought 3 of these and already installed the other 2. Now I'm about to do the last one and I'm confused. I turned off the breaker and the fan and light are now in operable. But my contactless voltage tester is showing something is hot there. I measured from each of the switch screws to ground with a voltage multimeter. It showed no voltage (maybe .005). Should I be worried about what is in the box?
All 4 of the black wires coming into the box are held together with a wirenut. And also for the whites. And grounds.
Is there something I'm not understanding here? Is the contactless meter just picking up a ghost voltage from a line run in parallel with the line turned off? I'm afraid to touch anything because I don't know what is happening on the tester in this situation that was not present in either of the other 2 installations. (or any other time I've used the contactless tester)
Thanks for any information.
(I also worked with LED circuits in my college class in 1966. And I built a nuclear magnetic resonance spectrometer while in High School in 1964 or so. Not fancy like the ones now, very basic)
