Problem:
NYC old Hotel/Residence-
HVAC company is claiming that dropped voltage is causing compressor problems that is lading to poor performance of the unit and sometimes dead of the compressor. I checked on that and on single phase 20 Amp rated circuit I am getting 197V and unit requires 230V
What would be the quickest solution to fix this problem. -without replacing the feeders in the building ...This is Landmark building so even changing of the A/C units is impossible .. Would installation of voltage booster transformer work ?? Did any of you have similar problem ? and how did you fix it.
Thank You All
Thank You All
