kosullivan
- Alpharetta, GA
I was called to a house where the owners UPS (APC 750 KVA) was shutting down because of overvoltage when the dishwasher or washing machine was turned on. I put two digital voltment meters on the PC circuit and the starting voltage is 122 to 124 with no appliances on and when the dishwasher or washing machne is turned on the voltage RISES to 135-137 volts on the DVMs.
I've never seen this situation before and am used to voltage drop as loads are added. When we put the heat pump on the voltge dropped from 124 to 122. The "A" and "B" legs at the panel are balanced and have the same high voltage. House is aerial fed from a pole about 150 feet from the house. Several incadescent blubs have blown when the appliances are turned on.
Any comments and ideas would be apprecited. I've never seen this before.:-
