NEC User
- Marlboro, NJ, USA
For a New York City Residential building, my understanding is Con Edison will provide either 120V/240V single phase service or 208Y/120V three phase service. I'm not sure of the Hz but, since it's America I presume 60Hz.
The mechanical designer submitted plans show most of the equipment rated for 208/230/1/60 and one rated for 220/240/1/50. I am not familiar with this notation. I think it means it will operate with 208V through 230V and the second will operate with 220V through 240V. I understand they are both single phase with the first one operating at 60 Hz and the second at 50Hz.
There aren't any 3 phase loads so it doesn't make sense for me to request 208Y/120V from Con Edison.
My questions are as follows:
What voltage should I request from Con Edison for this residential building? 120/240 single phase?
What does 208/230 mean?
What does 220/240 mean?
Should I tell the mechanical designer that he needs to revise his design to utilize only equipment that operates using 60Hz and either 120V or 240V?
