voltage spikes
JdoubleU
Thank you all for your answers and added comments. This forum is helping me lots in advancing my knowlegde as an electrician. I have A question about a lose neutral causing voltage spikes. What theory do you base your conclusion?
It's hardly a theory. It's just a fundmental fact.
A picture is worth a thousand words:
Lost neutral
Lost neutral
So if you lose a neutral in multiwire circuit on a 3 phase system the voltage would divide itself between the 3 phases.
A multiwire branch circuit in a 3 phase system would be 2 phases and a neutral with loads connected phase to neutral. So if you lost the neutral, then you would have a series circuit with phase to phase Voltage source, at least up to the panel where the circuit originated.
