RD35
- Bloomington, Indiana
Anybody out there ever had a problem with inductive (Wigeman or Knopp) testers causing GFCI outlets to trip needlessly?
Well now that you mention it....the gfci's that tripped on separate circuits were all within about 20 feet of each other and on #12 copper...just on different circuits. I'll try that and see if it makes a difference. I just cannot imagine why this little tester is tripping GFCI's and a carpenters big circular saw won't trip the circuits at all. Even plugged in a space heater pulling 1500 watts (resistive...not inductive) with no problem at all. Weird.How close was the tester to the GFCI receptacle? It's conceivable that if the tester is close enough to the GFCI, the stray magnetic field from the solenoid could couple into the toroidal transformer of the GFCI to cause it to trip. Particularly when you connect or disconnect it. Try testing the output of a GFCI receptacle with an extension cord on it to see if distance from the GFCI reduces or eliminates the tripping. If it still trips then it's an electrical effect and not a magnetic one.
You were using your tester between the Hot and an Equipment ground.
So you are convinced that the inductance from your tester is enough to trip a gfci randomly but the inductance from a power tool is not? I don't buy it.Nope. I was testing between the Hot and the Grounded Conductor (or Neutral as some call it), not the Gounding Conductor (ground wire). But yes as you stated I think there is some type of inductance generated ghost voltage causing just enough of an imbalance current in the trip coils of the GFCI's to activate them.
It had me worried at first until I had a chance to think through where everything was located it the circuit layouts. Then I realized there really was no other explanation for the trips...especially after doing power tool testing and circuit polarity testing (with my receptacle outlet tester that I later ran out and retrieved).
Thanks for the replies! This further confirms my conclusion that it was the inductance of the tester causing nuisance trips. I was still a bit skeptical of my own conclusion thinking maybe there was something I was missing or not realizing could happen. Being an engineer and not an installer I realize experience trumps most everything else when it comes to these types of problems!
For our AB experiment we purposely cycled the power to the contactor by rapidly inserting and removing a pigtail to the coil while we monitored the voltage at the coil. A simple insert, pause, remove did not trip the GFCI. Most use of power tools would fall into that category.So you are convinced that the inductance from your tester is enough to trip a gfci randomly but the inductance from a power tool is not? I don't buy it.
That's why I suggested a cord. If it still trips, it's the type of load; if it doesn't, it's the magnetism."Inductive kickback" sometimes causes GFCI tripping, if it is a solenoid type tester maybe this is what is happening?
