Matt Mckenzie
- United States
On a 120 volt circuit that is showing open grounding conductor with plug tester and a grounding conductor does exist and connected to the green screw hot to neutral shows 120 volts, hot to grounding conductor shows roughly 60 volts and neutral to grounding conductor shows roughly 60 volts. Is this okay and normal for a neutral to show voltage to an open grounding conductor? Is it okay to plug a new microwave into this circuit? Would this odd voltage from neutral to open grounding cause an appliance to short circuit components?
Confused please help
