Buck Parrish
- NC & IN
How can you have 50,000 volts on a taser gun, But, no current?
An open circuit. However, if you are in the circuit, some minimal current will flow and you will feel like you were just kicked by a mule.buckofdurham said:How can you have 50,000 volts on a taser gun, But, no current?
There are two electrodes.buckofdurham said:So does some how this laser gun let some energy back to the source. That way you feel like you are getting kicked by a mule. I am perplexd.
iwire said:I am sure you meant 'low' current?
The short answer is the power supply for the circuit is simply not capable of providing much current. The power supply is purposely designed to make high voltage with low current.
S'mise said:What would I equal then Zog? :-?
S'mise said:Roughly 10k ohms on the surface but when the darts penetrate into your skin it's probably less than 200 ohms.
There are never limitations on ohms law. However, there are limitations on the power supply as you have eluded to in your statement. Whenever you short the leads together, there will be a fault current flow. In the case of a person being the shorting bar and the 9 volt battery being the supply, this is really very interesting. Let's say the output voltage is pulsating DC at 50 kV and the human resistance is 400Ω, do you really think the voltage will be maintained and that there is anything less than a fault? If the voltage could be maintained, the current would be about 125 amperes through the human at 50 kV - not good.zog said:Whatever the power supply is capable of putting out. There are limitations on Ohms law.
