Dear All,
I need to know How to calculate the Voltage drop and what needs to be done to avoid voltage drop as per NEC.
e.g- I have a 1600Amps breaker ,480 Volt, 60hz and distance is approximate 1000 feet.
So how to calculate the voltage drop for this application.
I have seen formula on mikholt.com
VD= 1.732KID/CM
K- Constant for copper or Aluminium wire
D- Distance one way
CM- Circular miles
In my case K- 12.9 ohms
I -1600 Amps
D- 1000Feet
CM - how to take a value of CM here.
Kindly reply.
VD= 1.732KID/CM
D- Distance one way
CM- Circular miles
I -1600 Amps
D- 1000Feet
Kindly reply.
