Is what necessary? You could use Romex, I suspect, if it was arranged so that it was free from physical damage. Your proposed method seems most typical.big vic said:I have always used weatherproof boxes, vaportite light fixtures, sealtite and compression EMT fittings in coolers. Is it necessary?
The refrigeration equipment keeps the interior of walk-in boxes fairly dehydrated. I have been in walk-in boxes during certain failure modes in which everything is dripping with condensation. Plus, many walk-in's suffer occasional "wash down" during the normal cleaning process. For this reason, waterproof wiring methods seem prudent.big vic said:Just wondering if I'll have moisture problems using regular 1800 boxes, set screw fittings and armored cable instead of sealtite
romexking said:A walk in cooler or freezer will be a wet enviroment.
When you pipe into a cooler or freezer, the inside of the conduit must be sealed with silicone to prevent condensation traveling between the cooler and the warmer area outside of the cooler.
The water vapor travels from the warm side, where the air can hold more water vapor, to the cold side where it condenses. It is important to preserve the vapor barrier at the warm side of any penetration, and at the warm end of any conduits entering the cooled space.romexking said:A walk in cooler or freezer will be a wet enviroment. You might be able to avoid most conduit in a cooler by making a penetration above the light box by the door (pipe or sealtite into the box to provide power to switch and get to switched leg), and a penetration for each evaporator. The fluorescent lights can be accessed by drilling thru the cooler ceiling and piping directly into the back of the plastic housing.
