I really want to get this figured out.
It's a new walk-in freezer that is located outside about 3 feet from the structure. When I look at the various parts I try to visualize how it how all the pieces of the puzzle go together, but then I get confused...
I'm not focusing on the condenser, that's pretty straightforward.
It's the inside unit cooler that confuses me.
Basically this unit has the evaporator, I'll have a disco, probably located inside the unit on the back wall?
The defrost timer I'm assuming will be located inside the building adjacent to the freezer, so there will be the conductors for that.
There is a LLS and a t-stat mounted on the back side of the unit.
Then there's a twin lead conductor stubbing out the side of the unit which I'm told is the heating element. I'm not sure what to do with that...
I try and draw out a one line diagram to figure out my connections but get confused.
Obviously power Will come to the disconnect. Then power to the actual evaporator unit.
I'll need interconnecting conductors between the time clock and the evap unit.
I'm not quite sure how the LLS, the t-stat, and the leads for the defrost heater fit into the puzzle though...
Also, for the defrost timer I have 4 conductors (n, x, 4, 3). Does that get power from those conductors?( I.e.- only need 4 conductor, not additional for power)
Thanks for comments and input..
