a field built 120 ft by 16ft walk in box inside a warehouse that has 4 compressor on the roof of the building & 4 inside units, a 50 amp branch circuit is run to the roof top unit and from the roof top unit 3 circuits 1 480 volt fan circuit, 1 480 volt defrost heater circuit & 1 208 volt control circuit is run to the inside unit, the question came up about disconnects at the inside units (3 on each?), 440.3 (B) seems to refer you to other code sections, would a breaker lockout comply for the inside units or would disconnects be required at each inside unit, thanks in advance
