Wall clearance 800 amp panel
The general contractor for a job is indicating a new wall with a three foot clearance from a 3-phase, 208Y/120V panel rated for 800 amps.
Does this actually meet code?
- Mike -
charlie b
Lockport, IL
Semi-Retired Electrical Engineer
Yes it does. The minimum space required for working clearance depends on the voltage level, not the current rating. For under 150 volts to ground (and in your example the voltage to ground is 120), you need a minimum of 3 feet.
H.L.
Minimum distance
Minimum distance
Are you sure about that? I thought that the minimum distance was 36"
charlie b
Lockport, IL
Actually, you could get by with 35.5 inches. The table gives the limit as 900 mm, and provides an estimated value for the conversion to English Engineering Units as 36 inches. ;) :grin:
