A flexible cord cannot be used as a substitute for fixed wiring so IMO it is not permitted.They would be hardwired, not plugged into receptacle.
That would make things easy. I didn't think I could use NMB that way. There would be an exposed whip living behind the heater. The funny thing is these heaters are common. HD carries similar and my supplier sells them. So there must be a reasonable way to wire them.Can’t you just use nmb exposed? Seems like it’s not subject to damage.
When this has happened to me and I used nm I just put a longer push in connector not set screw or button in and it protects it the 1/2 in of romex. If you're using SO I don't think you can use it for that and for sure you can't use it in a wall.
Yes, that would solve it. I am just stuck on how to install these per their design. Anyway, thanks for the tipsCan the bracket be spaced off of the wall with something to allow a whip of MC, etc. to be used?
11.5.2 CON Premium 208–240 V models, hard-wired connection
CON Premium 208–240 V models have a junction box located at the right rear of the unit. Included in the junction box are wires with wire nuts attached. f Install a ½˝ ROMEX clamp in the knockout of the junction box at the rear of the unit to prevent the power cable from being pulled out of the wiring block during operation. f Cable must be routed from a circuit breaker of suitable size, through the ROMEX clamp, and connected using the wire nuts in the junction box of the unit. See section 15.3, “Wiring diagrams”, pg. 13.
120 V hard-wired connection
Trim the power cable so it leads directly to the heater connection socket. - Ensure that, after trimming the power cable, the heater can still be removed from the wall without issue. Trim the power cable by cutting off the plug. Connect the trimmed end of the power cable to a suitable appliance junction box. The appliance junction box must be connected to a circuit breaker of suitable size. See section 15.2, “Data table”, pg. 13
