geochurchi
- Concord,NH
- Retired electrician
Hi,what is required for a disconnect for a wall mounted oven?
Most guys here use the breaker with a permanently attached lockable means ( breaker Lock)
110.25 Lockable Disconnecting Means. Where a disconnecting
means is required to be lockable open elsewhere in
this Code, it shall be capable of being locked in the open
position. The provisions for locking shall remain in place
with or without the lock installed.
Exception: Cord-and-plug connection locking provisions
shall not be required to remain in place without the lock
installed.
Is there anything in code not allowing them to be receptacle & plug connected (as a means of a disconnect) if they come with a whip (tail) already on them ? :?
