wall oven and counter top stove-glass fused junction box
I am replacing a 28 year old wall oven and island /counter top stove with a newer set (5 years old)
I noticed the 8/3 conductor to each goes into a junction box,onder the counter and inside the wall oven's are two glass fuses ,as well under the stove top its junction box has 4 glass screw in fuses . The 8/3 conductor is fed from the panel from a double pole 40 amp breaker. Any installation instructions on line neither show nor talk about this kind of junction box. They only show a square"normal" box in which to make your connections.
Can I just eliminate the fused box for a regular junction box? Thank you
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
