Has anyone had compatibility issues with wall pack led lights and a after Market motion sensor? I installed a 81 watt wall pack with a motion sensor that is rated for 1.25 amps led. It was worki originally. Then started flashing after a couple of weeks. We tried installing a new motion sensor with photocell and it still is flashing when in test mode. Voltage readings line side is 120 volt, load side the voltage fluctuates from 160 volt to 117. The amperage without the motion sensor is .7 amps.
