thomas cox
New member
- Florida
were wall receptacles required to be grounded or bonded in 1981?
cripple said:The grounding of receptacles was required in 1962, which is the oldest NEC I have.
"Section 250-75 Bonding at Grounding-type Receptacles."
If the house was built and inspected using the 1962 NEC all receptacle would be required to be grounded through a bounding jumper, . . .
thomas cox said:were wall receptacles required to be grounded or bonded in 1981?
LarryFine said:Wouldn't that only apply to "grounding-type" receptacles, and not "all" receptacles? I'm quite sure the requirement for 100% use of grounding receptacles was not yet in effect.
