AlWired said:Is there anything in the code that says you can use a wall switch as a disconnect in a non-residence application?
Thanks in advance.
ItsHot said:I have even used them for a disconnect to a luminare!
I can't remember????Pierre C Belarge said:Where did you do that?...France :roll: :grin:
Copy-cat! :smile:Dennis Alwon said:I have used a dp 30 amp snap switch as a disco for a water heater.
forman400b said:Remember, a disconnect for motors 430.104 and appliances 422.35 must be indicating, so Decora type switches would not be acceptable.
brother said:You can write 'on' and 'off' on the decora switch!!and get it UL listed.
wireman3736 said:I used a 3 way toggle switch as a transfer switch to switch line power and generator power for a boiler, Is that code compliant.![]()
