czars
Czars
- West Melbourne, FL
- Florida Certified Electrical Contractor
Does anyone know who sells 20 A SPST (wall) toggle switches and receptacles for aluminum wire?
Pigtail a piece of copper to the alum and use a listed wirenut for co/al.czars said:Does anyone know who sells 20 A SPST (wall) toggle switches and receptacles for aluminum wire?
czars said:Good advice. However, if I could find switches for Al/Cu I would use them. Unfortunately, I've not found any locally, hence the reason for the question. Pigtailing would work too if there was room in the box for Ideal 65's but there isn't.
I scoured Leviton's site. CO/ALR switches are only available in 15a residential-grade.brantmacga said:our local big orange sells al/cu leviton devices. check w/ yours.
kelley said:....I did ask if they are available in TR yet and he did not think they were.
Kelley
LarryFine said:I scoured Leviton's site. CO/ALR switches are only available in 15a residential-grade.
The closest any of their 20a switches come is copper or copper-clad aluminum.
480sparky said:I don't see why they wouldn't be dual rated. Why take a known, working design when you start making TRs and redesign, reengineer and retool the terminals?
Aluminium was seldom used for small branch circuit wiring in my area, so the supply houses don't really stock al/cu devices. I have to go to Lowe's to get an AL rated switch or receptacle when the need arises. I try to keep one spare receptacle on the truck. I think they're about 4 bucks when I need one, but that's so seldom that it really doesn't matter. If you need it, you need it.czars said:The Big Box store near here does have 15 A switches and receptacles, but they are pricy.
