Wall TVSS w/overcurrent protections?
corville
New member
Do you know IF anyone mfrs/sells a Wall mounted Surge Protector 6 outlets WITH OVERCURRENT PROTECTION? School wants convenience of wall mount (no cord) but with TVSS & overcurrent protection also.
roger
Fl
Re: Wall TVSS w/overcurrent protections?
What is their reason for needing OCP at the device?
Roger
tom baker
First Chief Moderator
Levitons Industrial specification grade plug in TVSS devices have a resetable circuit breaker, models 5100-p, 5200-p, 5300-p. I have installed a lot of the 5100-p, we then use a standard metal non tvss plug strip. The plug in TVSS are less likely to walk away. Often I will use a plug strip with a 15 ft cord, the fire depts like plug strips, the long cord is good in older buildings.
However, the 5100-p is a lower protection model TVSS and I always have more TVSS at the panel.
