I am being asked to build a control panel that will be fed from 2 UPSs. The UPSs will be supplied with separate 120VAC circuits not necessarily from the same source. I can keep the UPS load side power separated in my panel except for some shared 120VAC loads and this is my problem. Can I install isolation transformers on the load side of the UPSs and then connect the neutrals? If I can I will then just use a contactor to switch from one UPS hot to the other. I do not care is I lose power to these shared loads during the contact switching.
