shawn73
- Napoleon, Ohio
Here my new project. I need to install a square D transformer (225 kva, 480 delta primary, 270 Primary side Amps, 208Y/120 Secondary, 625 Amp secondary) to power 3- 208/120, 200 Amp panels. I am planning on wiring the primary side normally. On the secondary side I plan to supply power to the top of 3 - 200 amp breakers (jumpering the tops with "full load" sized wire. The bottom side of each breaker will feed each individual 200 amp panel. I have several questions involving my plans.
1. Involving the top side of the 200 amp breakers: I have a potential of 625 amps on my secondary. I don't want to jumper 1250 kcmil wire across the tops of the 200A breakers. How do I calculate using 2 wires for each phase? For instance can I just use 2 runs of 300 kcmill (at 320 amps each for a total of 640 amps)
2. Is it acceptable to power three panels the way I am describing?
3. Is it legal to mount a breaker on the side of the transformer?
4. Finally, how do I calcuate the primary side breaker size, taking into account inrush current? Is there a % to full load especially for transformers?
Thanks a lot for your help. I just want to do everything correctly.
