They just delivered our new Full Modular Home. It came in three sections and has a 200 Amp service. Since it's new, the builder has to correct everything that is incorrect, or until we accept the package.
After switching on every checking and marking all the breakers in the fuse panel to ID each room and circuit, (just because I want to know if they doubled up any circuits) I found that the breakers on the left side are warm and the breakers on the right side of the panel are cold, (Or Room Temp).
The meter is barely turning, but it is turning.
Nothing is on in the house except the Smoke Detector circuit. One 20 amp breaker handles all 12 smoke detectors.
All 8 single pole breakers on the left side are warm to the touch when switched on, while all 8 single pole breakers on the right side of the panel are room temp.
I just turned all breakers, including the smoke detector off to let cool and recheck this afternoon.
With the breakers on, but no lights on, only the smoke circuit on the left side gets warm. It may be from only one circuit thats warming up the rest.
Should any breaker get warm to the touch if hardly any power is used thru that circuit?
Thanks
Thanks
